Posta all data som skickas här så kan jag hjälpa dig att sätta upp sensorerna i Home assistant. Kan tycka att säljarna borde ha en exempel MQTT men icke.
Med lite tur kanske @toreamun kan se om den fungerar med hans kod.
De har faktiskt det :D
enligt deras sida
esp32_A32B84/raw /ELL5\253833635_A 0-0:1.0.0(211118114800W) 1-0:1.8.0(00016867.262*kWh) 1-0:2.8.0(00000000.000*kWh) 1-0:3.8.0(00000000.182*kvarh) 1-0:4.8.0(00005210.512*kvarh) 1-0:1.7.0(0000.679*kW) 1-0:2.7.0(0000.000*kW) 1-0:3.7.0(0000.000*kvar) 1-0:4.7.0(0000.445*kvar) 1-0:21.7.0(0000.209*kW) 1-0:41.7.0(0000.390*kW) 1-0:61.7.0(0000.079*kW) 1-0:22.7.0(0000.000*kW) 1-0:42.7.0(0000.000*kW) 1-0:62.7.0(0000.000*kW) 1-0:23.7.0(0000.000*kvar) 1-0:43.7.0(0000.000*kvar) 1-0:63.7.0(0000.000*kvar) 1-0:24.7.0(0000.201*kvar) 1-0:44.7.0(0000.183*kvar) 1-0:64.7.0(0000.060*kvar) 1-0:32.7.0(238.4*V) 1-0:52.7.0(237.6*V) 1-0:72.7.0(239.9*V) 1-0:31.7.0(001.3*A) 1-0:51.7.0(001.9*A) 1-0:71.7.0(000.5*A) !6102 esp32_A32B84/Energy/Active/Positive/value 00016867.262 esp32_A32B84/Energy/Active/Positive/unit kWh esp32_A32B84/Energy/Active/Negative/value 00000000.000 esp32_A32B84/Energy/Active/Negative/unit kWh esp32_A32B84/Energy/Reactive/Positive/value 00000000.182 esp32_A32B84/Energy/Reactive/Positive/unit kvarh esp32_A32B84/Energy/Reactive/Negative/value 00005210.512 esp32_A32B84/Energy/Reactive/Negative/unit kvarh esp32_A32B84/Power/Instant/Active/Positive/value 0000.679 esp32_A32B84/Power/Instant/Active/Positive/unit kW esp32_A32B84/Power/Instant/Active/Negative/value 0000.000 esp32_A32B84/Power/Instant/Active/Negative/unit kW esp32_A32B84/Power/Instant/Reactive/Positive/value 0000.000 esp32_A32B84/Power/Instant/Reactive/Positive/unit kvar esp32_A32B84/Power/Instant/Reactive/Negative/value 0000.445 esp32_A32B84/Power/Instant/Reactive/Negative/unit kvar esp32_A32B84/Power/Instant/Active/Positive/L1/value 0000.209 esp32_A32B84/Power/Instant/Active/Positive/L1/unit kW esp32_A32B84/Power/Instant/Active/Positive/L2/value 0000.390 esp32_A32B84/Power/Instant/Active/Positive/L2/unit kW esp32_A32B84/Power/Instant/Active/Positive/L3/value 0000.079 esp32_A32B84/Power/Instant/Active/Positive/L3/unit kW esp32_A32B84/Power/Instant/Active/Negative/L1/value 0000.000 esp32_A32B84/Power/Instant/Active/Negative/L1/unit kW esp32_A32B84/Power/Instant/Active/Negative/L2/value 0000.000 esp32_A32B84/Power/Instant/Active/Negative/L2/unit kW esp32_A32B84/Power/Instant/Active/Negative/L3/value 0000.000 esp32_A32B84/Power/Instant/Active/Negative/L3/unit kW esp32_A32B84/Power/Instant/Reactive/Positive/L1/value 0000.000 esp32_A32B84/Power/Instant/Reactive/Positive/L1/unit kvar esp32_A32B84/Power/Instant/Reactive/Positive/L2/value 0000.000 esp32_A32B84/Power/Instant/Reactive/Positive/L2/unit kvar esp32_A32B84/Power/Instant/Reactive/Positive/L3/value 0000.000 esp32_A32B84/Power/Instant/Reactive/Positive/L3/unit kvar esp32_A32B84/Power/Instant/Reactive/Negative/L1/value 0000.201 esp32_A32B84/Power/Instant/Reactive/Negative/L1/unit kvar esp32_A32B84/Power/Instant/Reactive/Negative/L2/value 0000.183 esp32_A32B84/Power/Instant/Reactive/Negative/L2/unit kvar esp32_A32B84/Power/Instant/Reactive/Negative/L3/value 0000.060 esp32_A32B84/Power/Instant/Reactive/Negative/L3/unit kvar esp32_A32B84/Voltage/Instant/L1/value 238.4 esp32_A32B84/Voltage/Instant/L1/unit V esp32_A32B84/Voltage/Instant/L2/value 237.6 esp32_A32B84/Voltage/Instant/L2/unit V esp32_A32B84/Voltage/Instant/L3/value 239.9 esp32_A32B84/Voltage/Instant/L3/unit V esp32_A32B84/Current/Instant/L1/value 001.3 esp32_A32B84/Current/Instant/L1/unit A esp32_A32B84/Current/Instant/L2/value 001.9 esp32_A32B84/Current/Instant/L2/unit A esp32_A32B84/Current/Instant/L3/value 000.5 esp32_A32B84/Current/Instant/L3/unit A
Jag tror du kan köra https://github.com/toreamun/amshan-homeassistant och använda RAW topicen. Det ser ut som ren P1 output.
Kan @toreamun bekräfta?
Då får du allt gratis. Annars så gör man så här:
sensor:
- platform: mqtt
state_topic: 'esp32_A32B84/Voltage/Instant/L1/value '
value_template: "{{ value_json }}"
name: "Smartmeter L1 Volt"
unit_of_measurement: V
- platform: mqtt
state_topic: 'esp32_A32B84/Voltage/Instant/L2/value '
name: "Smartmeter L2 Volt"
ebolasmurf och 1 till
P1 läsare med extern wifi-antenn och ethernet ser ut til å sende alt du trenger for både MQTT sensor eller AMSHAN custom integration.
Enheten publiserer til topic som heter esp32_SERIENR (där SERIENR är enhetens serienummer). Det ser ut som den har et topic som heter raw som er hele meldingen fra elmätaren og et topic par (verdi og unit) for hver sensor (f.eks esp32_A32B84/Power/Instant/Active/Positive/value og esp32_A32B84/Power/Instant/Active/Positive/unit).
Hvis det er slik at value og unit er to ulike topic, så kan du enkelt benytte MQTT sensor til å sette opp en sensor for value, men unit må hentes fra et annet topic. Jeg er litt usikker på hvordan du går frem for å hente unit fra et annet topic, men en sensor kun med value og "hardkodet" unit kan settes opp slik @Fn87 skriver.
Hvis du benytter AMSHAN custom integration, så velger du esp32_SERIENR/raw som topic når du konfigurerer MQTT,
Fn87 Fn87 skrev:
Jag tror du kan köra [länk] och använda RAW topicen. Det ser ut som ren P1 output.
Ja, https://github.com/toreamun/amshan-homeassistant vil fungere med topic esp32_SERIENR/raw.
Integrasjonen mangler nå noen av sensorene som gir detaljer for hver fase. Men dette har jeg en plan for å få på plass.
Fn87 Fn87 skrev:
[länk] följ instruktionerna här. Följ där efter instruktionerna här: [länk]
Du kommer få en grunduppsättning av sensorer med hjälp av pluginet.
B^llocks.. ok. Ser nu att jag måste sätta upp en annan instans av HA.
Kör den via en app men det stödjer inte något extra märker jag.
Ska installera om på min gamla NUC till HA istället.
Tack så mycket för info och @toreamun! jag återkommer med hur det går efter installation.
återigen, tack tack!!
toreamun
Du kan installera manuellt också. Integrationen funkar på alla versioner av HA.
Ja, bare gi en lyd hvordan det fungerer. Så skal jeg hjelpe om det behøvs.
Det begynner å dukke opp mange ulike lesere, så jeg setter opp en WIKI hvor det kan legges opp detaljer om hvordan man får opp de ulike leserne.
men manuellt kräver cli... och appversionen saknar det. Tror inte appversionen kommer från HA projektet utan någon som gjort det själv.
Leif Nyberg2
Vilken version har du? Kan du länka?
Det är inga konstigheter att använda detta oavsett.
ebolasmurf
toreamun toreamun skrev:
Det står at den har HACS installert allerede. Da trenger du ikke CLI, men skal kunne installere rett fra HACS: [länk]
amshan finns dock ej när jag söker efter det. Tömt cache och provat med olika webläsare...
Det var den mest obskyra versionen av HASS jag sett, tätt följt av varianten man kan installera på en surfplatta. AlexxIT gör bra grejer så det borde bara vara att köra på. På sikt bör du fundera på en supportad variant men det kan vara skönt att se att det du vill ska fungera gör det.
