152 700 läst · 1 059 svar
153k läst
1,1k svar
Prylarnas pris: Pryl-HLR
Allvetare
· Västra götaland
· 8 921 inlägg
Frågan är väl också om det spelar någon större roll om det är "toxiska brandskyddsmedel" inuti en spis?
Absolut, jag är helt med. Menade på att visa att min inte innehåller något sådant toxiskt.P Paxman skrev:
Ser fram emot svaret från @spikplanka
anbusafety.com: Comprehensive Guide To Fire Blankets- All you need to know (2023-10-15)P Paxman skrev:
"Fiberglass: This is the most common material used to make fire blankets. Fiberglass is a material made from extremely fine fibers of glass. It is not combustible and is able to withstand temperatures up to 1000 degrees Celsius"
"Wool: Some fire blankets are made of wool that’s been treated with a fire-resistant chemical. Wool is a natural material that’s inherently fire-resistant to some degree, and the additional chemical treatment enhances this resistance."
Finns en variant till som kan vara värd att känna till:
"Aramid Fibers: These synthetic fibers are used in some high-performance fire blankets. They’re extremely heat-resistant and do not catch fire or melt, making them ideal for this purpose. Examples of aramid fibers include Kevlar and Nomex."
Mer om fiberglasfiltar:
firefighter.com.my: What are Fire blankets and what are they made of? (2021-11-25)
"woven strands of glass yarn intertwined in a flexible state. The material is a practical fire retardant substance made out of a mixture of silicone or graphite-coated fiberglass yarns."
Brandfiltar kan visst även fatta eld vid oljebränder:
firefighternow.com: Can A Fire Blanket ACTUALLY Catch Fire? (2022-05-21)
"Despite all that, fire blankets can indeed catch fire. A study from the Netherlands done between 2013 and 2014 through the Netherlands Food and Consumer Product Safety Authority dug deeper into whether fire blankets could ignite."
clasohlson.com: Fire blanket FB1212, Fire blanket FB1218 (2010-05-19)
Glasfiberfilt som innehåller:
Amorphous silica CAS no.: 7631-86-9
Aluminium oxide CAS no.: 1344-28-1
Calcium oxide CAS no.: 1305-78-8
Sodium oxide CAS no.: 1313-59-3
Magnesium oxide CAS no.: 1309-48-4
td;lr Det är primärt textilbaserade brandfiltar som har "additional chemical treatment" men ingen tillverkare verkar uppge vari denna består av men en hint kan hittas från de brominerade plastdelar till hemelektronik som ofta använt sig av flour, klor, brom, jod i olika föreningar som är rätt toxiska. För glasfiberfiltar är det standardfaran med fiber som sätter sig huden eller andas in.
Om det finns ämnen i föremålet som förångas så blir det ett problem. För glasfiberbaserade filtar är faran mest vid installationstillfället.Dan_Johansson skrev:
För textilier med "additional chemical treatment" är bromerade flamskyddsmedel inte sällan med. Det är kanske inget tillverkarna vill prata högt om.P Paxman skrev:
Du har med andra ord inga fakta som stödjer ditt påstående att "Brandfiltar är fulla med toxiska brandskyddsmedel." Det är en gissning du gör, och då bör du formulera dig så att det framgår eller avstå helt från att skriva.spikplanka skrev:
· Blekinge
· 10 225 inlägg
Kan själv!
· Trelleborg
· 15 631 inlägg
Kan själv!
· Trelleborg
· 15 631 inlägg
Eller så stjäl en kinesisk tillverkare receptet på elektrolyt från en japansk dito, som dock inte har det äkta receptet i kassaskåpet. Resultatet blev en stor mängd havererade elektronikprylar under flera års tid...
Kan själv!
· Trelleborg
· 15 631 inlägg
Jadu, det finns inte mycket annat att välja på om man vill lagra stora mängder energi lättåtkomligt i en liten förpackning.spikplanka skrev:
Detta är en av de få komponenter som faktiskt åldras, och gör man fel åldras de i förtid, vilket skett här.
Så sant, men marginalkostnaden för att välja någon bättre tillverkare är inte så hög. Dessutom kan man kanske designa annorlunda så att dI/dt inte blir så våldsam. Kanske rentav låta två kondensatorer dela på jobbet så att man får större marginaler osv.13th Marine skrev:
Kan själv!
· Trelleborg
· 15 631 inlägg
ChongX har säkert så bra priser att inköparen inte kan motstå 😉spikplanka skrev:
