11 476 läst · 69 svar
11k läst
69 svar
Hur kan jag stabilisera mina takstolar?
I am sure of it. I wrote about it earlier. The roof structure was stiffened by the roofing, battens and sheet metal. The walls are to blame, and the floor as well. The fact that the contractors were certified carpenters does not mean that they could not have messed it up. For me, the material is not suitable. Am I right that it is plywood? Plywood has many advantages, but one of them in this case is a disadvantage. Flexibility. Structural beams made of plywood have squares that stiffen them (look bellow). Here they are missing. What you write, that such a wall structure has proven itself many times, does not mean that it will also work here. First of all, it is a large cottage. Secondly, in this type of cottage, the posts usually run from the ground to the roof. And this changes the situation diametrically. To help you, you need to see some photos from the previous stages. And you have to be more open to this help...J Jens Widehammar skrev:
Ett antal bilder på själva väggarna utan taket påDowser4711 skrev:
Produkter som diskuteras: "stålband"
Montageband
Metallband med hål är mångsidiga infästningskomponenter, som erbjuder en praktisk lösning för en mängd olika bygg- och monteringsprojekt. Dessa band kan stärka förbindelser, bidra till en jämn belastningsfördelning, och fungera som en
Except being more open, do you want me to send you more photos from earlier on? Like the ones below? What would you like?S sturnus skrev:I am sure of it. I wrote about it earlier. The roof structure was stiffened by the roofing, battens and sheet metal. The walls are to blame, and the floor as well. The fact that the contractors were certified carpenters does not mean that they could not have messed it up. For me, the material is not suitable. Am I right that it is plywood? Plywood has many advantages, but one of them in this case is a disadvantage. Flexibility. Structural beams made of plywood have squares that stiffen them (look bellow). Here they are missing. What you write, that such a wall structure has proven itself many times, does not mean that it will also work here. First of all, it is a large cottage. Secondly, in this type of cottage, the posts usually run from the ground to the roof. And this changes the situation diametrically. To help you, you need to see some photos from the previous stages. And you have to be more open to this help...
Denna krysskolvning skulle i så fall sitta synliga i mitt fall..Hu många behövs? Kan man göra samma fast med stålvajer? Och kanske inte på alla takstolar utan typ mellan takstol 1 och typ 4?Tomture61 skrev:
På fackspråk heter det krysskolvning .
Man sätter i ditt fall en regel mellan toppen på en takstol som fästs i nästa takstol , men i botten (underarmen)
Tvärt om på takstol nr 2 , kommer att se ut som ett kryss från sidan .
Sätter man en spik mitt i krysset så blir det ännu stadigare .
Kommer bli mycket stabilt i sidled .
Ser ut som det sitter träskivor på yttertaket 👍
The latest photos of the TS show that this is a truly catastrophic situation. The structure does not have a continuous structure. No continuity of the foundations, caps, external load-bearing walls built of 22mm(!) plywood modules do not have any load-bearing structure! A steel strip is attached to this plywood, which was supposed to stiffen it. This is where the instability comes from. Of course, this can be remedied, but it will cost money. Unfortunately, it was supposed to be cheap, but it will be as usual. If engineers and companies were involved in this, I would pay an expert for an expert opinion and I would accuse them of acting to the detriment of the client.
I don't think that crosspieces are necessary here. I wrote that the problem is the instability of the wallsJ Jens Widehammar skrev:
En ovanlig åtgärd att behöva staga upp takstolar i sidled .J Jens Widehammar skrev:
Men stålvajer mellan några takstolar fungerar också , glöm dock inte att låsa ihop vajrar där de möts .
Takytan + vinden är starka krafter tillsammans.
