435 710 läst · 5 118 svar
436k läst
5,1k svar
Home Assistant
Jo vilken röra, i brist på annat så återställer du en burk så härnino skrev:
https://www.home-assistant.io/installation/generic-x86-64
Ett generiskt PC bygge och du ser väl vad det är för "burk"?
Plus att du måste ha backuperna på annan burk eller USB sticka.P paralun skrev:
och så här återställer du en backup
https://www.home-assistant.io/common-tasks/general/#restoring-a-backup
Yeah, for some reason I was assuming something like openconnect, which listens on 443 by default. But, well, none of that compares to open default SSH port anyway! 😆S snikanor skrev:Not at all. Wireguard uses UDP and will only reply to requests that are valid (see [länk]). Unless you publicly state that you have a WG server listening on a specific address and port the risk of an attacker attempting to break into it is extremely low.
Having an http or https server publicly available on the default ports on the other hand...
Edit: sorry, the person you were replying to wasn't talking about Wireguard, it was another person posting comments in parallel. If you use a VPN server that can be discovered by e.g. an nmap scan then yes, I agree with you. It will most likely draw the attention of more attackers compared to if you only had an http/https server exposed.
