29 854 läst · 252 svar
30k läst
252 svar
Net Zero måste alla hus byggas om till passivhus innan 2035-2050?
Det var något som jag hittade en länk till som verkade intressant och som belyser problematiken, en åtgärd som vissa verkar hylla, medan vi andra är djupt oroade över tilltaget.A akby skrev:
https://swebbtv.se/w/7nEtW9ozGiVD9yuAweGiu8
Läste en av länkarna i TS inlägg.
Fann det här som kanske säger något (tydligen är inte "lagförslaget" publicerat ännu):
From January 2030, all new builds will need to be zero-emission buildings, defined as “a building that has a very high energy performance” with the very low amount of energy still required fully covered by energy from renewable sources produced on-site.
From January 2027, all new buildings occupied or owned by public authorities will need to be zero-emission.
Existing buildings will also need to meet performance standards “so far as this is technically, functionally and economically feasible” when they undergo major renovation. This is when the total cost of the renovation is more than a quarter of the building’s value.
Alongside this, buildings sold or rented will need to reach class E for a transaction to take place after January 2027 and class C by January 2033.
However, there is still work to be done on performance standards, according to Oliver Rapf from the Buildings Performance Institute Europe.
“The introduction of minimum energy performance standards is limited to some selected trigger points which risks that many buildings will be left behind and won’t get a deep renovation,” he told EURACTIV.
The draft text is also unclear about whether these standards will cover commercial buildings or not.
“The leaked EPBD proposal indicates a comprehensive revision but the devil is in the detail. It contains a much too weak definition for deep renovation, referencing a threshold of 30% energy savings, which will be insufficient to achieve the 2030 climate goal,” he said.
The leaked EPBD draft also introduces a “renovation passport” for homeowners to keep track of works already performed and those that are still needed before the building can be considered zero-emission.
The renovation passport is meant to help homeowners stagger renovation works over several years as a way of spreading the cost. However, critics say this would also increase the hassle of renovating and split renovations over multiple occasions.
Håller med dig! Vi måste sänka vår energianvändning samtidigt som vi är kreativa och installerar exv vågkraft i haven, solceller på stora tak, solfångare på andra tak där den går direkt till värme och varmvatten. Vi måste utgå från verkningsgraden i de olika systemen och vad de kan användas till.M mrsnhp skrev:Kärnkraft är ett sätt att ordna fossilfri el, ja. Svensk elproduktion är ju (i normalfallet) i stort sett fossilfri tack vare vattenkraft och kärnkraft. Med det sagt är jag inte övertygad om att nya kärnkraftverk är the way to go, men där tycker jag att det är svårt att hitta information som inte är politiskt/ideologiskt färgad (vare sig för eller emot) så den diskussionen överlåter jag åt andra 🙂
All elproduktion har tyvärr negativ miljöpåverkan av ett eller annat slag, så vi behöver minska elanvändningen även om den är fossilfri. Därför välkomnar jag både bidrag för energieffektivisering av hus och skärpta regler för nybyggen och nyinstallation av värmesystem.
En absurd sak som oftare och oftare kommer upp är att solcellsparker tillåts anläggas på prima jordbruksmark. Verkningsgraden är under 20%, dvs ganska usel. Samtidigt förespråkar fler och fler att vi ska odla grönsaker i våra källare eller, enl Svt idag, i kök. Till detta ska vi använda energi från ffa solceller på samma hus…
Att det blir så dyrt att det blir omöjligt att på egen hand bekosta boendet, då kan vi nå den föreslagna agendan om att inte äga något, men ändå vara lyckliga.E Ekerz skrev:
"The devil is in the detail"....TRJBerg skrev:“The leaked EPBD proposal indicates a comprehensive revision but the devil is in the detail. It contains a much too weak definition for deep renovation, referencing a threshold of 30% energy savings, which will be insufficient to achieve the 2030 climate goal,” he said.
Nu är då ingenting klart och jag hoppas vi har kloka politiker i Bryssel.
Sen är ju Spanien ordförandeland nu under hösten (vi var under våren) och vad jag sett så är det prioriterat att få ihop Net Zero avtalen, både för byggnader och framtidens energiproduktion men djupt oense är man inom EU.
Man kan ju börja med att fundera om vi ska fortsätta att vara med i EU.A akby skrev:EU verkar ha ett förslag om att ALLA hus måste byggas om för att bli klimatneutrala. Kollar man på net zero verkar det vara ungefär samma som ett passiv hus.
Kommer det att fungera att bygga om gamla hus på landsbygden, och vem ska stå för kostnaden. Eller vill dom driva in alla till 15 minuters städer? Stämmer det här måste man nog tänka om med sina renoveringar och nybyggnationer.
Mer info:
[länk]
[länk]
De lägger sig i mer och mer i saker de inte borde ha någon rätt till.
Det är lite roligt nu att den icke folkvalde toppbyråkraten Ursula von der Leyen, plötsligt ändrat åsikt om EUs politik om rovdjuren, speciellt då vargen, i Europa.
Orsaken - hennes älskade ponny Dolly blev tagen av varg hemma på gården i Tyskland.
Även England som inte är med i eu är redo att ta till drakoniska åtgärder:
Ministers want to grant themselves powers to create new criminal offences and increase civil penalties as part of efforts to hit net zero targets. Under the proposals, people who fall foul of regulations to reduce their energy consumption could face up to a year in prison and fines of up to £15,000.
1 sep. 2023
1 sep. 2023
De har gröna kommunister i Storbritannien också, än så länge.A akby skrev:Även England som inte är med i eu är redo att ta till drakoniska åtgärder:
1 sep. 2023
Vi lyckades ju peta dem från makten här, det lär hända där också.
man tänkt flera gånger att EU sku fått vara EU i mitten och dom övriga 5nordiska länderna ett eget miniEU vilket jag tror skulle ha gynat alla bäst.. för i slutändan vad gör representanterna i EUparlamentet för dom nordiska länderna dom har ingen talan bara värmer sin stol och lyfter lönP paralun skrev:Jo och det är ju högrisk att det kan bli alldeles galet... en politiker på kontinenten har som huvudargument hur man ersätter fossilgasen och det har inte Sverige och Finland.
Sen är det då flera "Net Zero" paket och Buildings är ett, betydydligt viktigare är Industry Act där framtidens energiproduktion ska slås fast.
Tycket inte nå sådan här lag är vettig. Kommet bli sönderrenoverade äldre hus.
Bättre att bygga med mindre utsläpp. Så en extra skatt på byggmaterial som släppet ut mycket koldioxid, och dåliga byggen som måste renoveras alldeles för tidigt. Badrum som helrenovering efter 20-30år
Beror ju lite på vad de hittar på. Men det verkar sorgligt nog vara mycket piska och lite morötter.Bjor skrev:
I praktiken spelar det ju ingen roll om 100,0% av landets fastigheter är med på tåget. Otroligt mycket vunnet på att bara plocka lågt hängande frukt. Dvs. se till att resurserna satsas där de gör mest nytta och inte hålla på och peta i marginalen.
