We are using old Elpanna Ept13 thermia, that I will include a picture of it, as you know, we are approaching the summer ,
Just wanted to ask, what is the best boiler setting for summer , what changes shall I make ? Many thanks in advance ✋
It only handles your heating system which is probably not needed during the summer so to save electricity turn it off. But it also has its own built-in control with temperature sensors both outdoors and indoors so it should figure this out on its own.D Dav Davi skrev:
It doesn't heat the water when there is no need (with the right settings), but the cirkulation-pump keeps going. So I also suggest turning it off with the main switch.
To prevent it from clogging you can turn it on a few minutes once a month.
Many thanks for your reply, but if I turn the boiler off completely , how can we get hot water for shower/bathroom. (I would like u to know 😀that Im not a handyman —we live in rad house), Thanks✋H Håbbe01 skrev:
I used to have something similar. I just let it be the same. During the summer I still wanted hot water for showers. The water for the radiators is only warmed as much as needed. Since the temperature is 40 degrees you still need some heating. When it gets warmer outside that meter should go down.
Doesn't the tap water heater have it's own system? EPT-13 does not have any built in logic to control the tap water heatibg.D Dav Davi skrev:
