Vi har köpt en stuga där förra ägaren verkar ha målat med både Falurödfärg och akrylatfärg. Det verkar var blandat på olika delar av huset och vissa delar ser ut som att de har både falufärg och akrylat på samma brädor.
Vad gör man?!
Vi skulle verkligen behöva måla huset. Men med vad?
Hade hoppats på den nya Falu träfasadfärgen, men den går att måla över allt - utom just akrylat färg.
Tacksam för tips.
Vad gör man?!
Tacksam för tips.
I think in your case with mixed paints on the wall it will be the best. I painted the soffits and rafters. They were yellow acrylic. Painted twice. For now everything is ok.
Of course first I used this:
and metal brush
and metal brush
Thank!S sturnus skrev:
But was your paint acrylic or acrylate.
Apparently the Falu träfasad works om acrylic paint but not on acrylate paint.
I don’t really know the difference between the two yet.
But anyway I guess this paint is our best choose since it seems to be a big mix on our facade.
As I wrote earlier. The paint was acrylic. I was recommended this type of Falu at Happy Homes. I brushed and washed the surface with this agent. When I first painted I had the impression that it might not work. But the second coat was perfect. The basis is for the previous one to dry well.
