Hello,
I'm new to Sweden and in my house I have a heating system with low water pressure. The heating is not working.
I hope someone can tell me how to fill the system with water.
Top part looks like this:
- The red valve is leaking a little, which I guess is caused by the low pressure
- The black valve is labelled 'påfylln' but not connected to anything in the back.
The red valve
Bottom of the system:
Any help is appreciated.
The red valve
Fairlane
· Stockholms Län
· 12 776 inlägg
Fairlane
- Stockholms Län
- 12 776 inlägg
Hi and welcome tonthe forum.
We need more pictures. The red one is a security vent, of the pressure gets to high, it will open and release water. It should not be leaking, but it can happen. I had that problem a few years ago and wanted to put a new one in. I bought a new obe, quite expensive, but then it had stopp leaking and it has worked for 3 years now...
By setup is similar, so for inspiration I will attach a photo. The blue knob is where I can top up water.
Thanks for the replies. I took pictures of the parts I can easily access.I don't see a blue knob anywhere. I assume the water filling needs to be close to the pressure meter?
Läppförstoring med fillers , why?
Övrigt Off Topic -
How to fill up pellet heating system with water
Ved, Pellets, Flis -
The Brunn to nowhere…
Grund & Markarbeten -
What's the swedish name of this tool and where I can rent/buy one(in Goteborg)?
Verktyg, Maskiner & Fordon -
Problem med vattenfillterautomatik
Vatten & Avlopp
