I moved into an apartment with underfloor heating in the bathroom. The thermostat seems to be similar to this one: https://www.clasohlson.com/se/Golvvärmetermostat-nVent-RAYCHEM,-NRG-DM/p/36-6671
When I turn up the temperature, I can hear the thermostat click, and the symbol shows that it is heating. However, the floor does not get warm. I read similar threads, which suggested checking the current while the thermostat was running. I checked the current between 1 - 2 (see picture) and 3 - 4, both were sitting around 230V. If I understand this correctly, then the thermostat sends the current to the floor, so that should not be the problem.
Where can I continue the troubleshooting? If I check the thermostat settings, it says that the floor is somewhere between 23C and 24C, so I don't suspect that anything is wrong with the sensor.
Any help is much appreciated!
Tack så mycket!!
Tack så mycket!!
