Hello everyone,
I recently moved from the Netherlands to Sweden. I bought a house with a pellet heating system. It is from an Italian company called Mescoli Caldaie SRL. Model PB22 Ed.
Now it works fine, but I have no experience with those heating systems. When winter comes I want to make sure it continues to work well.
Unfortunately, the seller of the house did not speak English so we will (my Swedish is still very limited) so I did not understand everything. What do I need to know to keep it running? I understood that I need to add water sometimes?
The pellet burner is also from Janfire. From both units I can't find any manuals. There is also an electric cartridge. Does that mean I can switch between electricity and pellets for heating the house?
Thank you so much for helping me along the way.
Here is the manual for the burner, unfortunately it's only available in Swedish.
https://www.janfire.com/wp-content/uploads/2022/11/BA_BrannareFlex2-a_R5_SV_221124.pdf
And I think this is the manual for the boiler, also in Swedish. https://www.janfire.com/wp-content/uploads/Manualer/Mescoli-Integral/Gamla/BA_Panna_R2_SV.pdf
The manuals is from this site if you don't want to download the pdf's directly.
https://www.janfire.com/en/manuals-and-documentation/
Here is an english manual to the boiler-
The burner is of model Flex A wirh the newer model of the electronical box
https://www.janfire.com/wp-content/...Integral/StyrningMescoli/Duoflame-Janfire.pdf
· Blekinge
· 10 232 inlägg
I had a Dutch friend in Swedenn who had a pellets burner, and when I visited him one day he was all black in his face. He had two dust explosions earlier that day.
If you are going to use the electric cartridge make sure you have looked at
https://data.nordpoolgroup.com/auct...rency=EUR&aggregation=Hourly&deliveryAreas=AT
for the electrical prices. (unless you have a fixed price)
(and for that you need to know what electric area you are in, SE1, SE2 ,SE3 , SE4)
During winter when its really cold the electrical prices can go crazy high and running on electrical cartridge then will get really so expensive you just want to cry.
So understanding and using the pellets heating system is a very good idea as tho it can get expensive (depending on prices on pellets) it will not make you bankrupt
Hobbysnickare
· Västra Götaland
· 750 inlägg
Hi, and welcome.S Stephan1985 skrev:
The unit most likely provide you with hot water, both radiators and tap water, depending on the size of the water tank and pipes that is connected to it. The boiler could have various built in water tanks. One for tap and one for heating.
The heating system will be controlled using thermostat that regulates a shunt valve. I might be connected to a outdoor thermostat or an indoor one or fully manual. The shunt valve regulates the amount warm water that goes out to the radiators.
The pressure should be around 1-1,5 bars depending on the size of the system. If you loose pressure you might have a leak and need to refill water using the refill valve connected on incoming water supply. You should check with the owner if there is any known issues with pressure loss in the radiator circuit. However if air build up in radiators you can let the air out (small nippel on radiators) and then fill the system up with more water to get 1bar. Maybe that was what they mentioned?
If the boiler is used to warm tap water all year round then they probably use electricity from April through September, turning the burner on around this time when electricity prices go up. If you have a separate boiler for tap water then you should probably just need to run the burner for the heating.
I use pellets only for heating and uses about 1 bag 16kg a day trough out the winter. You can order bags or bulk online and have them delivered or buy them at your local hardware store. They cost around 90kr/bag.
Hobbysnickare
· Västra Götaland
· 750 inlägg
Just to clarify, the black box on top looks like the shunt valve and looks like it’s connected so it will automatically control the temperature.
If your boiler only supplies the heating look for other tap water tanks/boilers usually located in bathrooms, laundry rooms or basement and connected to the tap water lines.
Also need to mention that you might be required to do a fire inspection every other year and have a chimney sweep once a year if your city requires it. Regulations can vary locally. The fireplace is hopefully registered and you will get an appointment in the mail.
Thanks for all the replies! Appreciate it. Will check the manuals.
Hjälp - ny villaägare, stora sprickor i sockeln och fukt
Grund & Markarbeten -
Bygger nytt, hjälp sökes för köksplanering!
Kök -
Poolprojekt med ny altan, hjälp mig minimera framtida ånger.
Altan & Uteplats -
Hjälp! En grön växt växer genom väggen i vardagsrummet i nyköpt hus
Byggnadsvård -
Nybörjare i Sverige, hjälp att bygga rätt och hitta rätt fackfolk
Övrigt husrelaterat
