Hej, vi vill måla om vardagsrummet och behöver råd om förarbetet. Hoppas att det är ok om jag beskriver detaljer på engelska, det är lite lättare för mig. Svara gärna på svenska!
Currently, the wall is painted over a wallpaper. There are visible vertical joint marks at some places (jutting out on one wall, and sinking in on another). It's audible that the wallpaper is loose when tapping some places. On one wall there is a visible slight relief (3d) pattern.
I cut out different sections to figure out what is underneath, but need a little help with identifying the layers here, and deciding how to proceed.
A thick layer(s?) goes over the whole wall. Hand håller skadad vägg, flagnande målfärg, köpt skum plastic, närbild, inomhus, renoveringsarbete behövs.
What kind of lining paper is this, does it serve some thermal/safety/sound isolation purpose? It has a strong "fiber" grid and what seems to be spackel and/or something dark and hard, like sandpaper, in between the (sub?)layers. It detached from the wall in numerous small places - max cca 10x10 cm, but as soon as I start cutting out those pieces the surrounding paper also comes off easily so it's hard to stop. Should I try to fix/glue all the airpockets or take off this layer? If I take it off, beneath it is a raw wall. Hand pekar på flagande målarfärg på en vägg, skadad textur, renoveringsbehov, närbild.
If I should remove all this, do I then need to replace this layer or just put some spackel on the wall?
In case I can avoid stripping the whole thing off and having to 'bredspackla' the whole wall:
Part of the wall has double (triple? hard to tell) layers of wallpaper. Bottom wallpaper above lining paper seems to be very thick and has a feel of fabric.
Everything above lining paper comes off easily, but leaves behind a thin layer or soft yellow paper / fabric with a lot of "lint".
Delvis avlossad tapet, vägg, ojämna kanter, beige och vit, texturfokus, interiör, skada, reparation behövs.
Don't know if this is the bottom part of the wallpaper or the top of the lining paper, seems like I should remove it before painting as it might "drink" the paint, but not sure how to remove just this layer (lint)?
On the other side of the wall there are less layers. Everything above the lining paper also comes off easily, but this one leaves some white and glittery lint over the lining paper.
En bild av en vägg med skalad färg och tapet som visar underliggande lager och strukturer.
Same as with above, any suggestions how to prep the wall for painting?
Altogether, can I paint on this base lining papers, should I add a layer of thinner lining paper to avoid having to deal with all this lint?
K
Ser ut som vävtapet (glasfiber) som var väldigt populärt förr i tiden. Sedan verkar det vara vanlig tapet också. Tror det blir ganska jobbigt att riva bort allt så skulle nog använt renoveringsgips eller renoveringstapet för att få en slät yta att måla på. Dock måste du grovspackla först, där du rivit bort tapet.
AnRi_G
Som sagt, det är glasfiberväv.
Riv bort altl som är löst. Lägg inte energi på att få bort det som sitter fast. Sedan två alternativ.
1 spackla, och slipa
2 spackla de stora ojämnheterna, sätt renoveringstapet.
Jag har själv inte använt renoveringstapet. OM du skall spackla, så börja med att spackla stora ojämnheter ( kanter vid bortrivna bitar, skruvhål osv).
Sedan bredspacklar du två gånger (i teorin räcker två ggr, i prakitiken, om man inte är proffs får man räkna med att bättra stora delar en 3e gång). Slipa. När du slipar så hyr en vägg/takslip och tillhörande dammsugare. De slipar med en stor rondell och dammet sugs direkt. Det blir inte dammfritt, men den tar minst 90% av slipdammet. Jag har själv slipat ett helt rum på mindre än 2h, då var jag visserligen helt slut i armarna i ett par dagar. Som altenativ till hyra, finns det rätt billiga slipmaskiner av den här typen på ex. Jula.
Om du skall bredspackla, så finns det en del bra youtube videor med råd från proffs, om ex. optimal vinkel att hålla spackeln mot väggen.
AnRi_G
