70 288 läst · 248 svar
70k läst
248 svar
Schakta tomt med parkslide
Yes, injection between the 2nd and 3rd knuckle of each stalk used to be popular, as well as cutting the stalk at that same height and pouring in 2-3% glyphosate. Now they mainly use leaf spraying after the flowers fade and before the first killing frost, as it is more effective, uses less herbicide and uses much less labor.T turbo100 skrev:Hörde att injicera glyfosat med en spruta ner i hålrummet i stjälken funkade.
Det var en trädgård utanför EU som hade problemet jag hörde om och där var tydligen glyfosat inte förbjudet vilket det är för privatpersoner i sverige, bara bönder får pumpa ut massor om jag förstår rätt.
Produkten finns i tyskland.
[länk]
Not only farmers get to use glyphosate in Sweden. License herbicide specialists get to use it also. There is at least one licensed guy down on my area (västra götaland) who uses glyphosate combined with another chemical (not sure of the 2nd one). He guarantees full efficacy in a single application. I am dubious of 100% effective but he does offer a guarantee.
Do you have any contact information?B Brendhain skrev:Yes, injection between the 2nd and 3rd knuckle of each stalk used to be popular, as well as cutting the stalk at that same height and pouring in 2-3% glyphosate. Now they mainly use leaf spraying after the flowers fade and before the first killing frost, as it is more effective, uses less herbicide and uses much less labor.
No, but the guy was on Facebook.O Oliver 278 skrev:
I believe he put up “I am going to be in your area” postings in local Köp/Sälj groups.
I have tried searching for some of his postings but haven’t found them. They were posted during mid to late Höst last year (in time for the “Fall Window” (when the flowers fade and before first killing frost).
I will keep looking and let you know if I find rhe guy for you.
What area are you in?
Claes Sörmland
· Sörmland och stan
· 24 489 inlägg
Claes Sörmland
- Sörmland och stan
- 24 489 inlägg
Det är förbjudet att använda glyfosat i sin trädgård (2 kap 37 § växtskyddsförordningen). Det går inte att kringgå förbudet genom att ta in en yrkesman/företag - det är lika förbjudet att sprida glyfosat i trädgården alla fall.
Enda möjligheten att lagligt använda glyfosat i sin trädgård är att vända sig till sin kommuns miljönämnd och ansöka om dispens från förbudet i 2 kap 37 § växtskyddsförordningen. Dispens kan kommunen ge enligt 2 kap 39 § växtskyddsförordningen om det finns särskilda skäl för det. Ett krav för dispensen är att växtskyddsmedlet är godkänt av Kemikalieinspektionen och att användningen är förenligt med villkoren i Kemikalieinspektionens produktgodkännande. Det gäller alltså att ett företag har placerat en glyfosatprodukt på den svenska marknaden där tillståndet är så brett formulerat att det omfattar bekämpning av parkslide i trädgårdar. Och att någon är beredd att sälja tjänsten att yrkesmässigt utföra bekämpningen med denna produkt hos dig. När du väl har fått dispensen kan du släppa in bekämpningsföretaget i din trädgård.
Gissningsvis fördyrar denna byråkrati varje bekämpningsåtgärd med kanske 10 000-30 000 kr jämfört med hur ordningen var före oktober 2021 och man kunde köpa medlet på t ex Jula och bekämpa själv. Fantastiska politiker vi har!
Man kan också högaktningsfullt strunta i vad politiker och icke pålästa byråkrater hittar på och fixa det ändå.
Lite jävla fransk mentalitet måste vi väl ändå visa!
Thanks! Appreciate it!B Brendhain skrev:No, but the guy was on Facebook.
I’m in Härryda outside Gothenburg, next to Landvetter airport.
Good to have hime as a back-up plan if we do not manage to get rid of these plants while moving the dirt
O Oliver 278 skrev:Vi har fått ärva en tomt som vi nu vill bygga hus på. Nu när det börjar blomma så upptäckte vi tyvärr att det finns parkslide på tomten, vilket även schaktfirman reagerade på när dom skulle lämna offert för markarbetet.
Som jag förstår det är det näst intill omöjlig att bli av med, vilket vi kommer få acceptera.
Men nu till min fråga;
Finns det någon av er som har erfarenhet av att schakta en tomt med parkslide?
Vilken firma använde ni och vad blev merkostnaden?
Tanken är att om vi ska schakta med god marginal för rötter osv och på så vis hoppas att vi får bort/dämpar delar av tillväxten
Vi upptäckte också parkslide på tomten efter att vi flyttat in. Vi grävde bort 5 x 10 tons last med massor vilket blev ett utjämnat hål på ca 15x10m.O Oliver 278 skrev:Vi har fått ärva en tomt som vi nu vill bygga hus på. Nu när det börjar blomma så upptäckte vi tyvärr att det finns parkslide på tomten, vilket även schaktfirman reagerade på när dom skulle lämna offert för markarbetet.
Tanken är att om vi ska schakta med god marginal för rötter osv och på så vis hoppas att vi får bort/dämpar delar av tillväxten.
Hålet täckte jag med svart markduk + presenning och ballast. Lät det ligga så två år. Sticklingar kom allt ut första året men de drog jag upp så fort jag såg dem.
År två drog jag som sagt bort presenning etc. Nu är den död och borta.
Istället för att jämna till och göra gräsmatta av allting så håller vi på i år och gör halva hålet till köksträdgård och halva till stenterrassen/orangerie. Lika bra att lägga det där gräsmattan redan är skrot tänkte vi.
Lite tråkigt sätt men så gjorde vi och borta blev den.
Edit: klippte allt ner den de första somrarna vi bodde här. Men den var allt rapp att komma upp igen. Kändes som att den aldrig skulle försvinna. Men har man mer tålamod än mig kanske det går lika bra 🤷♂️
Tack för att du delar med dig. Vart körde ni massorna som blev över? Förstår jag det rätt om det blev ca 5 lass med lastbil?C Cdalsland skrev:Vi upptäckte också parkslide på tomten efter att vi flyttat in. Vi grävde bort 5 x 10 tons last med massor vilket blev ett utjämnat hål på ca 15x10m.
Den visar inga tecken på att tappa kraft initialt, men det gör den. Den blir av med en heldel energi i varje ner klippning. I alla fal om man släpper upp den en bit mellan klippningarna.
Yeah, EUmikethebik skrev:
LOL. I am outside of Hindås, neighbor!O Oliver 278 skrev:
Njae flak med traktor. Men jo, 5 lass blev det. Massorna slängdes/dränktes hos en vän, inte att användas till något. Park slide kan inte simma så vi dränkte massorna kan man säga. 🐟O Oliver 278 skrev:
En för stunden ny granne som arbetar som trädgårdsmästare såg att vi fraktade bort jorden. Hon undrade om hon kunde få litet. När jag nämnde vad det var ville hon inte ta i det med tång och tyckte att vi hade en bra plan för växtens sista vila 😅
Har du själv lyckats med det? Är mest nyfiken.D Daniel 109 skrev:
Som sagt så försökte vi klippa ihjäl den. Jag trodde tvärtom att vi klippte för sällan och att det var därför det inte bet. Tiden räckte sällan till att ha ordning på gräsmattan och den där park sliden kom allt upp en bit mellan klippningarna 😅
Sen trodde jag det var en nackdel att låta den växa upp eftersom bitarna du klipper av blir större och kan sprida sig därigenom?
Kommer särskilt ihåg sista sommaren med den där växten. Det var 2018, vilket var en väldigt varm sommar. Behövde inte klippa gräsmattan pga torkan då. Men den här park sliden, den växte allt den. Ushiamig. Då bestämde vi oss för vår ”final solution”.
Ja, jag har fått bort ett rejält bestånd jätteslide. Som är väldigt lik parkslide, och samma sak med glesare parkslide bestånd.
Där gick jag in på att dmta enbart dem och spara all annan växlighet minst en gång per månad i flera år. Parkslide har mycket energi i rötterna som de pumpar upp i åvanjordsdelarna under tillväxtfasen. Tar man dem snabbt hinner de inte göra av med energin.
Där har vi nog skillnaden på oss. Jag försökte klippa ihjäl den i 2-3 år. Jag var nog för otålig helt enkelt.D Daniel 109 skrev:Ja, jag har fått bort ett rejält bestånd jätteslide. Som är väldigt lik parkslide, och samma sak med glesare parkslide bestånd.
Bra info för TS dock 👍 just en sån tidsuppskattning var inget jag hittade när jag sökte info om det här när vi skulle ha bort vår planta.
Det är extremt stor skillnad på olika bestånd. Det kan ta allt mellan några enstaka år till väldigt många år att ta död på den med bara nedklippning.C Cdalsland skrev:Har du själv lyckats med det? Är mest nyfiken.
Jag och min kontakt på Statens Lantbruksuniversitet anser att det är bättre ju oftare man klipper. Daniel uttrycker sig som vanligt som att det han säger fakta och inte åsikt, men du kan nog ta det mesta han säger med en nypa salt.
Läs gärna mer om parkslide i mitt dokument. Där går jag även igenom samtliga andra metoder för att bekämpa parkslide. https://bit.ly/parkslide
