7 349 läst · 16 svar
7k läst
16 svar
Byta ventil Gustavsberg HE Radiator
Inralf-byggahus skrev:
Why not use a thermostat, like the Evosense suggested above? Personally I use these: https://store.danfoss.com/en/Climat...Built-in-sensor,-8-°C---28-°C,-M28/p/013G2761 (Danfoss 013G2761).ralf-byggahus skrev:
I do not really need thermostats. The rooms in our house are not really separated from each other, we mostly do not have any doors between the rooms and if, then the doors are almost always open (with the exception of the bathroom ). So all radiators are normally on 'fully open' and the heating system only is regulated by an outdoor temp sensor - all rooms are on the same temperatur. There are only a few radiators which have to be on 'low heat' (f.e. garage or cellar) and that can be easily done by a 'handratt'. I even was thinking about replacing the old valves by just a screw or a plug, if I wouldn't have been able to get the replacement valves.... To put a Handratt onto the valve is for optical reasons mainly. In Germany you get so called 'Bauschutzkappen' ('protection cap') for radiator regulation. That would have even been enough for me, but I do not get them with an 28x1.5 thread and suitable for the 10MZ10.
