1 087 läst · 7 svar
1k läst
7 svar
Tips about GräsKlippare
Hello Fellows,
I have around 600 Kvm Lawn and would like to have a grässklippare. Right now I Have a Ryobi electric one until now but would like to avoid electric gräsklippare now as I need to carry a cable all the time. Any good recommendation, should I go for a bensin or battery? I am thinking about bensin självgående. Any good model recommendation? I was thinking about biltema but then in multiple posts, I have checked feedback that it is not such a good product.
Personally I have a Husqvarna that runs on battery, LC 137i. I'm very happy with it. My lawn is a bit bigger in size than yours and it works very well with a battery. I would probably be able to do your lawn 2-3 times before having to charge the battery.
Not having to mess with gas is a big plus for me, and it's also much quieter than a mower that runs on gas. And much lighter, so for my part there is no need for it to be self-driven, my five-year-old could easily push it around himself (he won't for obvious reasons, but given how easy it runs and it's weight he could).
Thanks a lot. My 6-year-old would love to do that. I have purchased a child one just now for him. May I ask one supplementary question here, what is the battery capacity?tveksamt skrev:Personally I have a Husqvarna that runs on battery, LC 137i. I'm very happy with it. My lawn is a bit bigger in size than yours and it works very well with a battery. I would probably be able to do your lawn 2-3 times before having to charge the battery.
I'm also happy with my battery powered cutter. It's a Bosch 36V that cuts 42 or 43 cm wide. I have 2 batteries with 4Ah each. They are not enough for my 1000m2 yard, but it would work great for 600.
What are you trying to achieved with the lawn? Do you want a perfect golf course lawn or can you settle for less?
The “best” mowers are all cylinder mowers but they are fairly complex and not to mention expensive.
Rotary mowers are a lot cheaper and dead simple…but you can’t reach the same levels of cutting quality.
Personally I would almost always go for a petrol one but that’s mostly because decent battery powered cylinder mowers go for about 40k.
Tips på Robotgräsklippare !
Robotgräsklippare -
Tips på prisvärd robotgräsklippare
Gräsmatta -
Bygga in laddstation till robotgräsklippare i slänt? Tips på konstruktion
Robotgräsklippare -
Slipa knivar till gräsklipparen, tips från folk på golfbana.
Gräsmatta -
Tips på beg åkgräsklippare för villa
Trädgårdsmaskiner
