1 648 läst · 14 svar
14 svar
Tak råd i Engelska
I want to renovate a part of the roof, therefor I take off the tiles and the roofwood and fix new roofwood and then i put back the same tiles on the roof.
Do you protect the roofwood agains waterleak incase a tile is blowing off or break ?
If so, what do you use between the roofwood and the tiles ?
Takpap or vindpap or plastic or nothing ?
Thank´s for your advice
Mvh
Nol
Mvh
Nol
Moderator
· 52 011 inlägg
The exact type you need may depend on the angle of the roof. If it's less than 18 degrees (I am unsure of the exact figure) you need some special solutions.
If You have a roof with an angle of +/-45 degrees you should be able to choose almost any type. Only if there is a very low angle so that the water/snow has more problem running off there could be a need for special types of takpapper. Ask at your nearest retailer and they will guide you.
It's the YAP2200 quality you're looking for. It's a polyester reinforced quality. Stay clear of the mineral fibre reinforced YAM-type. The latter is used for sheds and other buildings you're not living in.
OK then it is going to be this one :
http://www.jemfix.se/Takpapp__11578/Underlagspapp-YAP-2200_9040737
Hänga ganska tunga saker i förrådstak
Byggnadsfysik -
Kapa korrugerad plasttak med sänksåg
Altan & Uteplats -
Vad heter stålpinne som utstakningsbrädor sätts på?
Grund & Markarbeten -
Vi har hela radhuset i med detta tak?
Miljö & Hälsa -
Boxer garageportöppnare med fjärrkontroll trådlös kontakt 1000N
Attefallshus, friggebod, garage & andra småhus
