963 läst · 2 svar
963 läst
2 svar
Is it okay to turn off the IVT490 heatpump while going on vacations?
I have an IVT 490 heat pump and going away for 3 weeks, is it okay to turn off the heatpump for that period? The last time I had configured it to vacation mode but still, it consumed a hell lot of electricity, that's why I don't want to take any chances considering high electricity prices these days.
If you turn off your IVT 490, how would your house get heating enough not to freeze water pipes? You haven't consider lowering the temperature more than the vacation mode do by default?
Also, consider the living conditions when you get home after your vacation and you then have to warm up your house to normal again. It will cost and it will take some time.
Yeah, you're right I didn't think about that. As you suggested I am considering lowering the heat setting by offsetting the heat curve along with the vacation mode.
I think setting the heat curve to 1 or 2 will do the job.
Omdöme av VISION HOME DIGITAL lås
Fönster & Dörrar -
Vad är detta för rör i mitt badrum och finns risk för fuktskador?
Badrum -
Mögel eller smuts? Titta och gissa!
Miljö & Hälsa -
Hur skall jag fästa mittkonsol Toyota Yaris
Övrigt Off Topic -
Vad göra åt vita fläckar på trall efter kisel-impregnering?
