1 157 läst · 7 svar
1k läst
7 svar
Furu fönster underhåll
Ursäkta jag skriver detta mejl på engelska - jag är en nybörjare på svenska.
We have moved into a house in Skåne (so a damp climate) that has clear/unpainted pine windows
I am guessing they need to be sanded, oiled and lacquered each season?
Can someone recommend which products to use on the windows each season here in Sweden?
Tack på förhand!
Stuart
Tack på förhand!
Stuart
Renoveringsnovis
· Dalarna
· 3 175 inlägg
I would go to a paintstore and ask them what they think Maybe not the answer you wore hoping for, but I am pretty sure they know what's best.
I would try "Nordsjö idé & design". They are a PRO-store, great products and pricey.
Renoveringsnovis
· Dalarna
· 3 175 inlägg
And btw; welcome to Sweden!
Grundstött
· Halland
· 28 358 inlägg
Here are two choises of different brands:
http://www.alcro.se/Utomhus/Arbetsomraden/FonsterSnickerier/FonsterSnickerier/Besta-fonster/
http://www.cuprinol.se/produkter/outdoor/dorr-och-fonsterfarg-v/
I have only used Alcro myself.
Go to a real paint shop and the will help you with oil, tools and all you will need.
And welcome to the Bygga Hus-forum Stuart!
PS
Right now it is probably much too humid to do outdoor painting.
You had better wait a cople of months before you start.
PS
Tack för alla svar och rad - och den varma välkommen!
If the windows are unpainted, (and not brand new), they have probably been treated with oil every seson. It is a solution if one does not want painted windows. The oil to use is okokt/rå linolja.
If you want to paint the windows I suggest to use linoljefärg. It is an old classic, and still the best in my view.
Linolja and linoljefärg and knowledge about how to use them is provided by f ex Ottossons (https://ottossonfarg.com/). You can also try with byggnadsvård (google).
Produkter som diskuteras: "rå linolja"
Linolja rå Ottosson
För inoljning av trä m.m.
139 kr inkl moms
Tillverkare av gedigna träfönster i kärnfuru
Fönster & Dörrar -
Obefintligt underhållna fönster, vad göra?
Fönster & Dörrar -
Furufönster, vilken glans på lacken?
Färg, Måla & Tapetsera -
Fönsterbräda av furu, minst risk för slag?
Underhåll av listen mellan fönsterkasetten och fönsterramen?
Fönster & Dörrar
