Hello
I see other posts related to this but it doesn't cover what my problem is.
I live in southern Sweden and have problems with the humidity in the garage. It sometimes goes up to 90 percent. I have a garage with storage as in the picture.
In storage the humidity is below 70 percent and when I use elements it is even lower but it is the garage where I have problems with humidity.
What I tried
Dehumidifier 30 m² from Christmas but it works when the temperature is above 5 and I have to put elements that take some time to raise the temperature.
My question is, can I use the exhaust fan (two way control) available on amazon (attached picture) that is shown in red color in outlet to control the humidity?
I have the front and one side of the garage not insulated, should I do that first and use dehumidifier or fan heaters? I am attaching a photo where the garage front and one side are not insulated. Resten av garaget och butiken är isolerade som på bilden
If anyone is interested, I use polycam app and blender
Thanks in advance.
What I tried
Thanks in advance.
The attatched graph showes the relative humidity outdoors at my home during november. Unless you heat the garage or use a dehumidifier you will not acheive much less humidity than outdoors. Ventilation is not enough since it is also very humid outside.
I use https://woods.se/sv/shop/avfuktare/woods-sw42fw-made-in-sweden/ in my 45m² garage. The garage is insulated but currenly without an heat solution.
I can push RH below 50%, but i try to keep it just below 70%.
Afaik theres no need to heat the garage from a humidity point of view. While the dehumidifyer doesnt work well around 5c, mold wont grow either because its too cold.
November power consumption of my garage dehumidifyer above.
How much energy does it take to reach +20C in the garage @Tomture61 ?
I have to have 20 degrees in the garage for various reasons. Do not have a separate electricity meter for the garage, yet.Unikt namn skrev:
Just wanted to show the humidity I have in the garage.
I don't see what temp you have. Or humidity .
Since I have no heat its pretty close to the oustide temp.Tomture61 skrev:
I havent gotten around to log my RH yet, i just have standalone temp/rh sensor.
My point was just that heat is not needed JUST for keeping RH in check. Its more economical to just dehumidify.
I am only concerned about mold, if that doesn't happen, I can move my garage's expensive equipment to a small store where I have both temperature and humidity control using oil element, thanks to good insulation.Unikt namn skrev:I use [länk] in my 45m² garage. The garage is insulated but currenly without an heat solution.
Sutteränggarage fuktspärr
Fuktskada kontroll men min granne vägrar att samarbeta
Juridik -
Garageport ny fjärrkontroll
Teknik -
Fortfarande hög luftfuktighet i garaget
Fukt i hörn på garageplatta
