Hejsan, någon som satt upp barngrindar i en linkande trapp som den här under, vill inte skruva upp något i väggarna då det är tretex. Varje trapp är ~90cm.
alla förslag är välkomna ..
![D1O72js-F0ixileofZyjR2Ww4t89e8tc2gNsWcf0Zk6Lu3rEtHihryjAKtbJIj5r1bYKfVgEv775I_DURSgXsHq8Sj_4RK3a9rAKPytieczKU3iTLbLjz1pxDxrpcY0P_SOnaIKAy4tZPG_BswwFWyDFBXqr5oCD73zJ23GqWPT-_iE2tRm2gteAAw23N_71c40u_HEuln-Pkp-wOqg8ZhhJbYfc45REF7hoGipuvDDJa1PSCgrIMejxbMAG1vaIgYmuQ5wDmKmGPiauLTK2xcI4noJfgU4DA9c2P5wtQaE5DnWaCFurg0jCg0iu0RpOW86tiX9nj86o9edrNGQy8Yju185mTmDQ7zJpwZuz7E8bmX9VlTe3Ayvv8zLlCJOqfdaskz0ynOBwjNG0NZxS4cFogJ7BxihLKTL5SGvyeeW13vTznZ_HXNIqpvoTZXF5zucClohV-JmWvZ0oOsrB95fY1_8bjNsdMcF9gUDATPqUpYQcOOIQAVLz3AXM6LjyRZLyve1I8G3-Agci3LhFOROTxpDFF3weBTGqwK7nvVS49r5cGVmaCykFpzPGjR7RDuJg5b3oIzV2mdufYWujWbfP9MDmR64KgzIY0eyUl2SqXRCDmmIWE5XGtdp0gtZWUnqrnnYb9jTKQsA2ModH5wrmNGlQyaQAlA=w1103-h552-no D1O72js-F0ixileofZyjR2Ww4t89e8tc2gNsWcf0Zk6Lu3rEtHihryjAKtbJIj5r1bYKfVgEv775I_DURSgXsHq8Sj_4RK3a9rAKPytieczKU3iTLbLjz1pxDxrpcY0P_SOnaIKAy4tZPG_BswwFWyDFBXqr5oCD73zJ23GqWPT-_iE2tRm2gteAAw23N_71c40u_HEuln-Pkp-wOqg8ZhhJbYfc45REF7hoGipuvDDJa1PSCgrIMejxbMAG1vaIgYmuQ5wDmKmGPiauLTK2xcI4noJfgU4DA9c2P5wtQaE5DnWaCFurg0jCg0iu0RpOW86tiX9nj86o9edrNGQy8Yju185mTmDQ7zJpwZuz7E8bmX9VlTe3Ayvv8zLlCJOqfdaskz0ynOBwjNG0NZxS4cFogJ7BxihLKTL5SGvyeeW13vTznZ_HXNIqpvoTZXF5zucClohV-JmWvZ0oOsrB95fY1_8bjNsdMcF9gUDATPqUpYQcOOIQAVLz3AXM6LjyRZLyve1I8G3-Agci3LhFOROTxpDFF3weBTGqwK7nvVS49r5cGVmaCykFpzPGjR7RDuJg5b3oIzV2mdufYWujWbfP9MDmR64KgzIY0eyUl2SqXRCDmmIWE5XGtdp0gtZWUnqrnnYb9jTKQsA2ModH5wrmNGlQyaQAlA=w1103-h552-no](/forum/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2FD1O72js-F0ixileofZyjR2Ww4t89e8tc2gNsWcf0Zk6Lu3rEtHihryjAKtbJIj5r1bYKfVgEv775I_DURSgXsHq8Sj_4RK3a9rAKPytieczKU3iTLbLjz1pxDxrpcY0P_SOnaIKAy4tZPG_BswwFWyDFBXqr5oCD73zJ23GqWPT-_iE2tRm2gteAAw23N_71c40u_HEuln-Pkp-wOqg8ZhhJbYfc45REF7hoGipuvDDJa1PSCgrIMejxbMAG1vaIgYmuQ5wDmKmGPiauLTK2xcI4noJfgU4DA9c2P5wtQaE5DnWaCFurg0jCg0iu0RpOW86tiX9nj86o9edrNGQy8Yju185mTmDQ7zJpwZuz7E8bmX9VlTe3Ayvv8zLlCJOqfdaskz0ynOBwjNG0NZxS4cFogJ7BxihLKTL5SGvyeeW13vTznZ_HXNIqpvoTZXF5zucClohV-JmWvZ0oOsrB95fY1_8bjNsdMcF9gUDATPqUpYQcOOIQAVLz3AXM6LjyRZLyve1I8G3-Agci3LhFOROTxpDFF3weBTGqwK7nvVS49r5cGVmaCykFpzPGjR7RDuJg5b3oIzV2mdufYWujWbfP9MDmR64KgzIY0eyUl2SqXRCDmmIWE5XGtdp0gtZWUnqrnnYb9jTKQsA2ModH5wrmNGlQyaQAlA%3Dw1103-h552-no&hash=a5fcd75cf0f657cec608eadf9864b57f)
Lägger upp ett förslag som är fungerande sedan drygt 8år. Gjorde en egen i vanlig 45x45 regel obehandlad gran. Personligen tyckte jag att de som fanns på marknaden då i alla fall var för klena. Har heller ingen anledning att ta bort den då det känns säkrare även för vuxna.
Nja, jag har högre krav på estetiskalösningar .
Husägare
· Sörmland
· 1 453 inlägg
Det må så vara att estetisk skönhet har haft lägre prio i mitt exempel. Men med tanke på ditt inledande inlägg så var kravbilden ganska ringa.C Christoffer L skrev:
Jag hade följande kravbild:
-Robust, Enkel, Stadig, Hållbar över tid, Nötningstålig, Snabbt att ordna, Billig samt Ändmålsenlig.
Det tog några kvällar att såga till och limma, inga onödiga skruvar finns i själva grinddelen. Så som jag uppfattade frågan var själva infästningen en del av problemet, där skulle jag haft mycket svårt att lösa med en "klämgrind" eftersom då hade trappräcket gett med sig och grinden kunnat lossna ganska lätt.
Sammanfattning: En förstärkning av räckesdelen kan vara en "komponent" i hur du undviker infästningar som tar laster i tretexväggarna.
det blev en Baby Dan, FLEX Grind, XL ![Glad :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
så här blir det
