4 496 läst · 4 svar
4k läst
4 svar
Anslut solar panel i Engelska
I have 2 sets of 3 solar panels overcomplete and I like to install them at our vacationhouse in Sweden
Each set contains 3 panels of 200Wp so total for one set is 600Wp
Overhere it is very simple, I can connect the inverter directly in the wallplug so there is no special connection to the power board. If I connect both sets to one wallplug then it is not allowed to make other wallplug in the cable from the power board fuse to the wallplug for the 2 sets.
How is it in Sweden ?
Mvh
Nol
Mvh
Nol
It is not allowed to connect solar panels to a regular circuit, and it is also not allowed to use plugs.
Installations should be hardwired directly to the fusebox using a separate circuit breaker (fuse) and a lockable switch.
In practice, this means that you need an electrician to hook up your panels.
Fel paneler i SolarEdge?
Bastuvägg i källare med betonggolv. Hur ansluter du den mot golv. Väggen skall vara träpanel och golvet skall ha plastmatta uppvikt mot väggen.
Utbyggnad och tillbyggnad -
Anslutning av trädäck mot lockpanel
Altan & Uteplats -
solaredge sortera paneler ?
Se hur panelerna är kopplade solaredge
